LTCache for Windows Upgrade Assistant
BlooTech
Post by BlooTech »
Does the default Client LTCache not work with the Windows Upgrade Assistant? Or is this option only if you dont have a LTCache currently setup for clients? Basically I'm unsure if I need to create a new policy per client (since LTCache locations/creds are different) or if leaving that option unchecked it will default to the LTCache that's setup at the Client Location? Since the ISO can only be downloaded a handful of times in 24hrs from GDrive I'd like to be sure its going to the LTCache so its only 1 download per client.
Re: LTCache for Windows Upgrade Assistant
In current versions it does not use or attempt to use LTCache.
This is something we can look to add as a feature.
