Please pull the plugin logs for that time frame and post it here. Did script get scheduled but fail or do we not see any schedule at all?jallenEITP wrote: Sat Nov 07, 2020 3:11 pm Script schedule still does not work. Set scripts on 11/6 to run on 11/7 after 12:30 am and nothing happened. Had 80+ systems that needed to be updated.
Habitat Upgrade Assistant - Scheduler Not Working
Re: Habitat Upgrade Assistant - Scheduler Not Working
jallenEITP
- 7
The scripts show scheduled in Habitat but they did not run at all for any system scheduled after midnight. i will try to get the logs.
jallenEITP
- 7
Did not have the Habitat Plug IN Logs enabled and this is a cloud server. I have enabled the Plugin logs in Habitat. I can schedule another one for tonight to see if it runs.
Thanks,
Need to see if the automation is failing to schedule your scripts or if it is reporting some other issues.
jallenEITP
- 7
NO access to logs. Can only show you that it was scheduled in Habitat and nothing shows up on the system for that time frame. I have added an attachment with screen shots.
- Scheduled for Wednesday at 12.docx
- (108.14 KiB) Downloaded 552 times
jallenEITP
- 7
I have the logs form the server now. I will not post them to this forum for security reasons so if you can provide a secure location to give you those files.
