Powershell Errors
G2G1
Powershell Errors
Post by G2G1 »
Having trouble when launching the shell on a machine. I've tried the verify options and even the previously posted xcopy commands as well for similar issues.
Re: Powershell Errors
Your problem is the Powershell build your using on the local computer can not see in its know paths the MSOnline Powershell modules.
So if they are actually installed on the local system, find them and make sure that they are in the path seen by your POSH version. The command is trying to load and use module to contact Microsoft but is failing to see the modules.
Did you see this post?
viewtopic.php?f=51&t=5175&sid=a96730e89 ... 06ab108232
This may help as well.
G2G1
Post by G2G1 »
I had seen that post and watched that video - didn't seem to cover this.
I resolved via:
Get-Module -ListAvailable
and then removing the msol/azure ones via Remove-Module NAME
Then redploying via your panel
Awesome,
