Error running Stalled Agents
djdlc425
Post by djdlc425 »
I'm trying to run stalled agents using Screen Connect utilizing the RMM+ plugin and I get the following error:
Starting Screen Connect connections to xxxxxxxxx Sending wakeup call
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
I have input the RMM+ Access code in the Stalled Agents Plugin
I also notice that under Offline SC Agents, it states no agent data returned by RMM+. I'm wondering if I set it up incorrectly??
dolphinvern
Re: Error running Stalled Agents
Post by dolphinvern »
I'm also getting the same issue, started after updating CW Control RMM+ to Version: 1.0.13. Suspecting the Stalled Agents plugin isn't communicating properly w/ RMM+ anymore (RMM+ is working and other integrations that query it are working fine).
djdlc425
Post by djdlc425 »
Is anyone monitoring the support forums?? I posted a few months ago and haven't received a support reply??
Sorry we missed this one,
I will look into it as soon as we return from ITNation Explore..
bmcfarlane
Post by bmcfarlane »
I am getting this error as well on multiple agents. Any updates?
kuuser
Post by kuuser »
I'm getting this error as well. RMM+ is working with other integrations. We just upgraded to Automate 2019 so it might be that -- the plugin says it's only compatible up to 12 (doesn't mention 2019). I'll wait a few days to see if there's a reply here and then just cancel our subscription.
We are looking into this and should have some info early next week.
kuuser
Post by kuuser »
Hi Cubert any update on this? Thanks
What version of RMM Plus are you using?
kuuser
Post by kuuser »
Our Automate plugin for RMM+ is version 1.0.0.15
On Control the plugin plugin shows as being 1.0.25
Edit: I was looking at the "RMM+ Password Link". The normal RMM+ plugin in Control shows as being version 1.0.14
