All of the Sudden Expired?
dpltadmin
Post by dpltadmin »
I was using PR just fine yesterday.
Today all of the sudden everything is turned off, version 1.0.0.1 (was 1.0.4.41) and says the License is Expired. Order shows fulfilled and should be active.
I've verified the plugin (v1.0.4.41) is DB Loaded and IIS Loaded
I've tried Reload DB Agent Plugins
Restarted DBAgent and Control Center. Still coming up the same
Automate v2019.2
Please Advise
Thank you
Re: All of the Sudden Expired?
Did you guys update your LTHost name?
Send me a private email at support@plugins4automate.com with your host name as you have it in the dashboard of server and the email address of the account used on our site and we will fix it
sindri
Post by sindri »
Same here, It says expired but I have a receipt of renewal.
Tried reloading the plugin, disable and enable again, reloading DBA, uninstalled and installed it again. But no luck...
Ok send me a private email at support@plugins4automate.com with your account name and I will get you fixed up..
