Error #1: UNKNOWN: Authentication Error
I have a few servers which are reporting this error. I've tried to perform due diligence and rule out user error. In each case I've logged on to a local system on the network, connected to the ESX host with vSphere and verified the credentials entered in the plugin are valid and allow login. Anything I'm missing here?
Error #2: Plugin never scans host
I've got 1 or 2 of these as well. I've entered the information into the plugin but the host is never scanned. There are no failure messages for these. Again, I've logged onto a system on the local network and connected to the ESX host via vSphere to make sure that I have the IP and credentials correct.
Error #3: OK
I have 2 of these, where the host appears to have been scanned, but the only response that I receive is "OK". Any more verbose logging or error syntax here?
Error #4: ConnectionError: Socket error: [Errno 10061] No connection could be made because the target machine actively refused it
I have several of these as well. Again, in all cases I've connected to the local network and then logged in to the ESX host with vSphere. My first guess is that there are services or daemons that aren't running, but I'm not sure which the plugin is requiring. I'm experiencing this on ESX hosts with and without SSH enabled. What can I do to correct this?
