Windows Defender for Automate- firewall rules
Windows Defender For ConnectWise Automate plug support forum. Post issues and questions here.
cbacon
Post by cbacon »
I am looking for a plugin to manage Defender Firewall rules will this product do that? If so are you able to disable the AV functions of trying to activate Defender as the local registered AV product in Windows? I want something I can just mange Defender Firewall with.
Re: Windows Defender for Automate- firewall rules
No This plugin manages Defender AV and Malware.
However, I like the idea of managing the firewall rules.
I will look into the process of listing all available rules, adding and removing rules and enabling and disabling the firewall at the domain, public and private levels.
This should'nt take to long.. allow me two weeks to code it all out and get it nested into the Defender plugin.
We have now released build 1.0.6 for Defender for Automate that adds Windows firewall management to the tool.
You can now enable and disable the firewall, view, add and remove firewall rules and enable/disable individual rules inside the plugin.
Return to “Defender For Automate”
