Error - > Conversion from string "" to type 'Date' is not valid
revero2749
2
Post by revero2749 »
We have been having this error for a while the moment we click on the filehog tab on the client console
We have also update to version 1.0.5,but the plugin still seems to reflect v1.0.4 in the filehog interface
How can we resolve this error?I think it is causing the background scripts not to run properly etc as we dont get results at all anymore
Re: Error - > Conversion from string "" to type 'Date' is not valid
Sounds like you have a stuck DLL on your local PC.
Here is how to fix.
viewtopic.php?t=5523
revero2749
2
I have done that already with no luck
What I have not done yet is perhaps remove the plugin completely from automate,including the .dll file on the automate server.then reinstalling it afterward,the .dll could be stuck on the server instead maybe
Thanks for pointing that out,I will provide feedback once I have done a fresh install on the server of the plugin
Test the plugin dll by right clicking it and selecting properties.
Is the file version showing 1.0.5 on the plugin you install to server? This image is for Patch Remedy but your FileHog DLL should show it's version here as well.
Screenshot 2024-05-22 142144.png (21.62 KiB) Viewed 148436 times
revero2749
2
2024-05-23 02_32_27-GLC-MIS-AUTO - ScreenConnect - Connected.png (31.28 KiB) Viewed 148432 times
I have removed the plugin completely from automate
I made sure the .dll is not in the automate server program files directory
I cleared the labtech lugins folder on the server and also cleared the control center cache all at the same time before restart the db agent service and then logging in to reinstall the plugin again and clear the plugins folder and cache folder again afterwards before testing with no luck
I am not sure if there is an issues with the .dll file or some sort of ready permission or maybe with the plugins DB tables,but I have cleared those tables too.I wish I had the 1.0.4 .dll file still just to see if it resolves the issue
sethayes
1
Post by sethayes »
Was there a solution for this?
I just installed it, as well (1.0.5), and it's throwing the same (Error- > Conversion from string "" to type 'Date' is not valid.) error whenever I open [Agent] > Plugins > FileHog.
I've logged out of CWA, and back in as Administrator.
I've deleted everything out of C:\ProgramData\LabTech Plugins\ and logged in to CWA as Administrator.
Edit: Plugin is also showing v1.0.4 - didn't notice that before.
Here is the link to 1.0.5, update your plugin, restart the DBagent and close and reopen Control center. Lets see if that resolves your issues.
https://delivery.shopifyapps.com/-/dcfc ... 05059505e2
I did a quick review of this plugin and see its was last updated some time in 2014-2015. Looks like there are several prereqs required to get the plugin functional. The code is a bit dated so I am going to refresh this plugin today to 1.0.6 that fixes and simplyfies the install to just installing the plugin DLL file alone.
Be back soon...
Wow, that was a piece of work I will say...
We now have build 1.0.6 available[HERE]
We have completely rewritten the code so that you will no longer need to install multiple things to get the plugin to work. Just install the DLL file as a install or as a upgrade to existing install then upon success restart the DBagent on the Automate host. Depending on size of Automate agent loads the DBagent restart may take several minutes to complete.
You will see a new Hog My Files script in the Scripts -> Maintenance -> Hog My Files
This script should have 1.0.6 in the script notes, a quick verify shows a successful install.
The old script directory "FileHog" can be manually removed and any scripts left in it also removed.
Client Tab
The Client Tab has changed to include a wider and easier to read layout.
Agent Search View
Updated all views with fill columns and increased size.
Agent File Viewer
The big change here is how the export happens and where file is saved. After export it will ask if you want to open the file making a confirmation of data quick and easy.
sethayes
1
Post by sethayes »
Looks like it's working - thank you!
Going to toy around with it and report back if I stumble across anything :)
Return to “FileHog File Analyzer Plugin”
