can't enable surflog
I can't see how to enable the plugin as described. I can open the plugin but it looks like it is not enabled
- surflog2.PNG (44.28 KiB) Viewed 13410 times
- surflog1.PNG (30.29 KiB) Viewed 13410 times
Re: can't enable surflog
Can you validate that your not showing expired?
Click the squid image in the right upper corner of plugin view. May need to enlarge window some to see it.
If expired and you have an active subscription then we may have your Automate host name incorrect in license server.
Send us your account email and we will look you up and verify the host name with you.
