Client Specific Apps or Exclusions?
DigitalOptix
Post by DigitalOptix »
Starting to play around with App Genie and have a few questions:
1. Is there a way to manage a list of apps to update at a client level (rather than just global)? I don't see anything, so I'm assuming not, but figured I would ask.
2. Is there a way to exclude a particular global app from being updated on at a Client, Location or Agent level? For example, if I had a subset of computers that needed to remain on Java 8 Update 121 (bad example, I know), is there a way of accomplishing this?
Thanks!
Re: Client Specific Apps or Exclusions?
App Genie was meant to be very simple and with very little control needed. If you want to control the packages, the deployments to different agents and clients then I would suggest you have a look at Chocolatey for Automate.
It Chocolatey For Automate is the full blow version of what App-Genie attempts to do for you as updates.
Return to “App Genie”
