Demo Mode in Chocolatey for Labtech
Posted: Fri Aug 24, 2018 7:40 pm
My company is looking at purchasing the Chocolatey for Labtech plugin. I downloaded build 2.0.1.91 for testing and it installed successfully. However, the plugin does not load in Demo Mode and does not show the 5 free licenses for testing. Instead it shows zero licenses available. Is there a way to enable Demo Mode for this build, or do I need to install an earlier build?
I did try the beta of Chocolatey for Automate but am wanting to compare it with the wider range of features in the Labtech version.
Thanks for any assistance you can provide!
