Demo Mode in Chocolatey for Labtech
jtech
Post by jtech »
My company is looking at purchasing the Chocolatey for Labtech plugin. I downloaded build 2.0.1.91 for testing and it installed successfully. However, the plugin does not load in Demo Mode and does not show the 5 free licenses for testing. Instead it shows zero licenses available. Is there a way to enable Demo Mode for this build, or do I need to install an earlier build?
I did try the beta of Chocolatey for Automate but am wanting to compare it with the wider range of features in the Labtech version.
Thanks for any assistance you can provide!
Re: Demo Mode in Chocolatey for Labtech
sure email us your LT host name to support@. make sure to put in the plugin name so whom every gets the request knows the plugin your working with.
