Powershell Console not working, big red errors
Posted: Mon Nov 07, 2016 5:34 pm
If you are seeing Module errors when launching Powershell consoles from our plugin then have a peek at our video at https://youtu.be/cNzR__QoM0U
As of build 2.0.0.57 the module installer accounts for 64 bit module loads and adjusts accordingly.
Re: Powershell Console not working, big red errors
Posted: Tue Nov 08, 2016 3:19 pm
If you have upgraded from 2.0.0.55 then you will want to verify modules again on workstation before using shell.
This will cause the modules to be copied over to the c:\windows\syswow64\windowspowershell\1.0\modules directory as well as the default directories so that the new shell will work correctly after update.
