JAVA
Posted: Sat Feb 13, 2016 1:55 am
by revsmitty
I've finally got this plugin working and I've been quite happy with it, but I can't seem to get JAVA to update on any of our machines. It will work if I the job locally, but it doesn't seem to do anything via the plugin. Other apps install and update fine.
Any suggestions?
Re: JAVA
Posted: Mon Feb 15, 2016 2:11 pm
It has to do with the way the package was built and needing Admin Privs and a logged in user. We are looking in to ways to better resolve this issue. But currently it is outside of our ability to manage another maintainers package needs.
We have in the interim added a "As admin" switch for apporved packages that may help in deployments
Re: JAVA
Posted: Mon Feb 15, 2016 5:24 pm
by vkent39
Is there a way to change the common apps to install AsAdmin?
Re: JAVA
Posted: Mon Feb 15, 2016 5:30 pm
Thanks to revsmitty, I went back and had a look at the As Admin piece to see if there was a reason it may not be working as intended and sure enough we missed a place where we inject the correct script to do the "as admin" functions. We have corrected this and released build 2.0.1.32 to address this problem.
Keep in mind Java has some requirements for install. Desktop must be logged in for admin script to function.
Re: JAVA
Posted: Wed Feb 17, 2016 8:48 pm
by revsmitty
Cubert wrote:Thanks to revsmitty, I went back and had a look at the As Admin piece to see if there was a reason it may not be working as intended and sure enough we missed a place where we inject the correct script to do the "as admin" functions. We have corrected this and released build 2.0.1.32 to address this problem.
Thanks for this. Still haven't been successful with JAVA, but at least you are giving me hope.
Re: JAVA
Posted: Fri Feb 19, 2016 12:59 pm
Also have we looked at if the user had a browser open during your install attempts?
Re: JAVA
Posted: Wed Sep 07, 2016 4:34 pm
by jerbo128
Any updates on this? We're still not able to get java to update successfully.
Re: JAVA
Posted: Wed Sep 07, 2016 8:36 pm
Post the errors you are getting from the scripts and or commands tabs.
Also is deployments tab in global showing system install attempts past 3?
Re: JAVA
Posted: Tue Sep 13, 2016 6:31 pm
by jerbo128
The global attempts are showing 0 on almost all of the machines.
AsAdmin is ENABLED
Tested 2 machines
Machine 1 - NEW INSTALL
Parameters: cmd!!! /C "C:\ProgramData\chocolatey\bin\choco.exe" install -fy jre8
Output: Chocolatey v0.10.0
Installing the following packages:
jre8
By installing you accept licenses for the packages.
jre8 v8.0.101 (forced) [Approved]
Searching if new version exists...
Downloading jre8
from 'http://javadl.oracle.com/webapps/downlo ... eId=211997'
Progress: 0% - Saving 156.86 KB of 52.63 MB (160621/55186496)
Progress: 0% - Saving 343.29 KB of 52.63 MB (351525/55186496)
......repetitive content removed.....
Progress: 11% - Saving 5.97 MB of 52.63 MB (6258101/55186496)
Progress: 11% - Sa
END of COMMAND LOG
SCRIPT LOG
Chocolatey v0.10.0
Chocolatey detected you are not running from an elevated command shell
(cmd/powershell).
You may experience errors - many functions/packages
require admin rights. Only advanced users should run choco w/out an
elevated shell. When you open the command shell, you should ensure
that you do so with "Run as Administrator" selected. If you are
attempting to use Chocolatey in a non-administrator setting, you
must select a different location other than the default install
location. See
https://chocolatey.org/install#non-admi ... ve-install for details.
For the question below, you have 20 seconds to make a selection.
Do you want to continue?([Y]es/[N]o):
Timeout or your choice of '' is not a valid selection.
jre8
jre8 not installed. The package was not found with the source(s) listed.
If you specified a particular version and are receiving this message, it is possible that the package name exists but the version does not.
Version: ""
Source(s): "https://chocolatey.org/api/v2/"
Chocolatey installed 0/1 packages. 1 packages failed.
Failures
- jre8 - jre8 not installed. The package was not found with the source(s) listed.
Version: ""
Check out Pro / Business for more features! https://chocolatey.org/compare
MACHINE 2 - UPGRADE from 8.31
COMMAND LOG
Output: Installing the following packages:
jre8
jre8 v8.0.91 (forced)
Downloading jre8 32 bit
from 'http://javadl.oracle.com/webapps/downlo ... eId=207773'
Installing jre8...
jre8 has been installed.
Downloading jre8 64 bit
from 'http://javadl.oracle.com/webapps/downlo ... eId=207775'
Installing jre8...
Searching if the previous version exists...
The install of jre8 was successful.
Chocolatey installed 1/1 package(s). 0 package(s) failed.
Re: JAVA
Posted: Wed Sep 14, 2016 12:47 pm
From your post it looks as if system #1 failed because it sat waiting for a Y/N response. The package was passed a -fy which is "force" and "Yes to all" so whom ever built the package or maybe even choco 10.0 may be to blame for that. I will check with Rob's team at Chocolatey to see if there is something we can do for that.
On system #2 it appears to have installed from the logs, did it install or was that a manual run from you? You may try the JRE8 command normally "without asAdmin" and see if you get past this as it runs as "system". See if you receive the same waiting for Y/N prompt.
Post back here your results
jerbo128 wrote:The global attempts are showing 0 on almost all of the machines.
AsAdmin is ENABLED
Tested 2 machines
jre8
Downloading jre8
Progress: 11% - Sa
END of COMMAND LOG
SCRIPT LOG
Chocolatey v0.10.0
(cmd/powershell).
location. See
jre8
Version: ""
Failures
Version: ""
COMMAND LOG
jre8
Installing jre8...
Installing jre8...
