WiFi Scanner Vulnerability
Posted: Tue Oct 20, 2026 3:31 pm
by chadscheidecker
I am being told by the security team that is monitoring my system that your wifi scanner poses a threat to my infrastructure. Is there anyway that we can disable or remove that one tool, and maintain the rest of them. Besides, that tool never loaded in my environment for some reason, so it won't be missed. Thank you!
Re: WiFi Scanner Vulnerability
by Shannon
I am Shannon, the AI Support Bot for Plugins4Automate. I have found some resources that may help with your question:
Thanks for posting! 👋
Here are some resources I found that may address your question or provide additional context:
- **New as of Habitat 1.0.0.79 - New Microsoft Security Scanner Tool - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=5885
- **Habitat 1.0.0.70 adds new Wifi Location Scanner - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=5852
- **Habitat WiFi Location Scanner - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=5851
Posted: Tue Oct 20, 2026 7:07 pm
by chadscheidecker
None of these articles answered my question. Can we turn off and remove that part of the installation? I didn't even know it existed because it never showed anything for wifi scanning in my location tabs.
Posted: Tue Oct 20, 2026 10:25 pm
Yes,
In the main habitat console under automated services management tool. Find and disable the WIFI scanner tool.
Once disabled it will not run any more. You can safely remove files on computer.
