Client Volume Viewer
Posted: Fri Oct 31, 2025 2:48 pm
Volume Viewer
This tool allows you to view the current status of all drive volumes across the client. A computer may show multiple entries for a single volume is that volume has multiple key protectors assignbed to them. Each key is dented by it's Key ID. You can see the status of each volume encryption and the security information needed for keys.
If you did not create the key protector using BitLocker for Automate then keys like Password or Pin and not available for these types of keys. We will however capture any Revovery Keys reported by computer.
Use the Export button to save an Excel Spreadsheet of the volume viewer.
Re: Client Volume Viewer
Posted: Thu May 14, 2026 3:04 pm
by Shannon
Thanks for posting! 👋
- **If Volume is currently locked scans will show Unknown as the status. - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=6601
- **Chocolatey for Automate not bringing app versions through and no managed apps available to deploy at the client level - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=6275
- **Client Volume Viewer - Support Forum**
https://support.plugins4automate.com/viewtopic.php?t=6616
