Excessive Script Queue
Posted: Thu Jan 30, 2025 4:49 pm
by Quill0
We found there are excessive script queues in surflog, which was causing performance issues with Labtech, is there a way to reduce this?
Re: Excessive Script Queue
Posted: Mon Feb 03, 2025 2:38 pm
Can you expand on Excessive Script?
Surflog is scheduled to run 4 times a day on each enabled agent. If the agent is offline or otherwise not executing script schedules then on each scan cycle the old schedule is removed and a new one is put in its place.
This means that there should only ever be 1 scheduled script entry for any one agent. The script to scan agents is extreemly small and quick so, by it's self should not be a drag on the agents executing script. Are you seeing somthing different?
