Chocolatey For Automate Build 3.7.0.11 Released
Locked
We have released build 3.7.0.11 today which has the following updates.
Very cool addition to network caching service. Thanks to (Stein Erik Andersen) for all the work to define and support the development of this new feature.
#1 The cache management script now analyzes each .nupkg file downloaded during the caching process. It searches for and modifies any chocolateinstall.ps1 file inside the .nupkg for local cache paths and changes them to the correct network share path.
This should fix issues with applications like Google Chrome that write the local cache location into the chocolateinstall.ps1 files used to install or update the application.
#2 Updated the EDF tab in the client console so that all check boxes react to clicks and not check changes.
Build availabel here or auto update will update the plugin.
https://delivery.shopifyapps.com/-/82e5 ... 9ae014768e
Locked
