Win 11 upgrade failing?
ITWG
1
Post by ITWG »
Trying to manually force the upgrade fails and trying to schedule it fails.
The Script(613) failed in the Else section at step 78. The reason: Script step has been running for longer than 6 hours, exiting step
Script: S613 - Starting at Server Time: Friday, January 10, 2025 2:21:30 PM
IF F5 ValueOne (P1): MYCMD Comparer (P2): 2 ValueTwo (P3): SCAN T: 1.4671684
L2 F70 Value (P1): SLEEP Comparer (P2): 0 To (P3): Jump (P4): :TIMETOSLEEP T: 1.4671684
L3 F139 Note (P1): :TIMETOWORK T: 1.4671684
L4 F70 Value (P1): MYCMD Comparer (P2): 2 To (P3): INSTALLKBFROMLIST Jump (P4): :INSTALLKBFROMLIST T: 1.4671684
L5 F70 Value (P1): MYCMD Comparer (P2): 2 To (P3): UPDATEALL Jump (P4): :UPDATEALLWINDOWS T: 1.4671684
L6 F70 Value (P1): MYCMD Comparer (P2): 2 To (P3): UPDATEKB Jump (P4): :UPDATEWINDOWSBYKB T: 1.4671684
L9 F70 Value (P1): MYCMD Comparer (P2): 2 To (P3): UPGRADEWIN10 Jump (P4): :UPGRADEWINDOWS10 T: 1.4671684
L62 F139 Note (P1): :UPGRADEWINDOWS10 T: 1.4671684
L63 F154 Folder (P1): c:\temp T: 1.4671684
L64 F115 User (P1): T: 7.4895595
L71 F139 Note (P1): :UPGRAGEWIN10USERCONSOLE T: 7.4895595
L72 F116 Question (P1): 'Windows needs to update your c...' Console (P2): 0 Jump (P3): :STARTWINDOWS10UPGRADE T: 7.4895595
L77 F139 Note (P1): :STARTWINDOWS10UPGRADE T: 99.8469915
L78 F235 T: 99.8469915
ITWG
1
Re: Win 11 upgrade failing?
Post by ITWG »
Support? Mods ? Admin??
Windows 10 to 11 upgrades are some what finicky. There are several pre-reqs that have to be met or accounted for to get a successful install. It sounds like from your logs that the script launched on agent and stalled. We have been working on a new function in our Habitat plugin that has had some good success and changes how we deploy Windows 11.
Part of this new function sets several registry cursers and pulls the latest WIndows Update agent from Microsoft.
I have now added this function to Patch Remedy 1.0.5.21 now available.
Available here
https://delivery.shopifyapps.com/-/f4db ... 1fabe6ed5c
The plugin should auto update tonight.
Try again with the same agent and send me the logs if you fail.
Ups, guess I was not fast enought!
I made a few updates to Patch Remedy to help with the WIndows 10 and 11 OS Updates.
See if this has any effect on your agents.
PR Build 1.0.5.25
https://delivery.shopifyapps.com/-/c867 ... 6c7bcfa413
Make sure to restart the DB agent after update to plugin.
Return to “Patch Remedy 5”
