New install of Habitat
nwbts
2
Post by nwbts »
I installed the plugin and entered hostname into account on plugin website. Still getting expired message on plugin.
Re: New install of Habitat
We gotcha nwbts!
Should be good now.
nwbts
2
Post by nwbts »
Thanks, It works now
jmercer0530
2
Post by jmercer0530 »
I have just installed the Habitat plugin and I am getting the expired message. I believe I added the hostname appropriately.
Ok, I checked your account, Your hostname is setup correctly, I found your license in the system and applied it to your host. You should now see it enabled.
Let me know if not.
