License Expired
Posted: Tue Feb 22, 2022 2:25 pm
by tmabaker
I have several subscriptions Habitat, MapDrives, and Office365, all are saying my license is expired.
Re: License Expired
Posted: Tue Feb 22, 2022 2:30 pm
Tammy, I just sent you an email. It looks like you might be behind a firewall or some SSL proxy that is interfering with the license request.
If you respond back to the email with the information requested we can have a look at the logs to see if you are actually reaching out to us or not.
Let us know if you cant find email
Re: License Expired
Posted: Sat Nov 28, 2026 8:56 pm
by jenniferjones
All three licenses failing at once points more to a blocked licensing connection than separate expirations. If there’s TLS/SSL inspection on the network, try allowing the vendor’s licensing endpoint, and confirm the system clock is accurate. The logs support requested should show whether the request is leaving the machine.
