MISSING MSOL EVENTS?
Posted: Wed Oct 20, 2021 7:42 pm
Up untill 3.0.0.4 we had a table mismatch for MSOL events causing it not to save the data.
If you are or have used one of these earlier versions you will need to go into your SQL and drop the plugin_p4a_office365forautomate_events and then restart the DBagent on the Automate Host.
SQL code to drop table
Once table is dropped and dbagent restarted a new plugin_p4a_office365forautomate_events table will appear and have a TenantID column.
Re run you MSOL scan to seed the data for client.
DROP TABLE `plugin_p4a_office365forautomate_events`;Re run you MSOL scan to seed the data for client.
