Initial setup wrong?
Posted: Tue Mar 30, 2021 1:46 pm
by automatedummy
Hey guys I have a new site setup with Chocolatey for automate. I have the apps in the main Chocolatey and then I have the site that I want set to enable. I selected the apps but none seem to auto install the location is also set to enable, what am I missing it has to be easy.
Re: Initial setup wrong?
Posted: Tue Mar 30, 2021 2:05 pm
Posted: Tue Mar 30, 2021 6:57 pm
by automatedummy
Looks like it is all set right. Is there a way to speed the timer up instead of 12-24 hours?
Posted: Wed Mar 31, 2021 1:55 pm
Which plugin are you using? If C4A then no, C4L does allow more control over automation.
