PowerShell script cannot run as admin
Posted: Tue Feb 02, 2021 9:24 pm
The script log shows the following when the plug-in fails to install a package on a PC:
Chocolatey v0.10.15 Business
Chocolatey detected you are not running from an elevated command shell
(cmd/powershell).
Does anyone know where the installation scripts are deployed from or if there's a way to explicitly make them run as Admin?
(cmd/powershell).
