Killing LTSVC.exe
Posted: Wed Jan 15, 2020 9:33 pm
Hi there,
It would appear the script stops and starts the services easily but I've tested this on numerous stalled agents and I get the same response each time. I don't understand. LTSVC.exe is definitely on the machine(s).
I've logged into a stalled agent PC and I can see LTSVC.exe running. Is there a reason why this error could be occurring?
Starting Screen Connect connections to *PC Name Here*, Sending wakeup call
Agent Online time in second (if a negitive number then it is the number of seconds offline) -> 76589
Sending Windows commands to restart the LT Agent
Stopping LTService ->
C:\Windows\system32>net stop ltservice
The SADOS Managed Services service is stopping.
The SADOS Managed Services service was stopped successfully.
Killing LTSVC.exe ->
C:\Windows\system32>taskkill /im LTSVC.exe /f
ERROR: The process "LTSVC.exe" not found.
Starting LTService ->
C:\Windows\system32>net start ltservice
The SADOS Managed Services service is starting.
The SADOS Managed Services service was started successfully.
All commands completed.
Edit: I did log on and opened an elevated command prompt and run taskkill /im LTSVC.exe /f manually to test. This succeeded.
