Can this be used with Workstations and set on a schedule?
It seems I can initiate a manual backup from a Workstation successfully but the "scheduled" backup never occurs. I've also attempted to do this on the same workstation manually using the WBAdmin enable command but it also does not seem to go off the scheduled time. So is the schedule option only for server OS? I'd like to setup a weekly backup of workstations, and trying to figure out if this software will accomplish this adequately.
