Installing DLL Issue
Posted: Thu Jan 19, 2017 10:12 pm
by jerbo128
Unable to import the DLL into labtech.
"there was an error uploading the new plugin: could not load file or assembly 'Fil:///c:\users\\.....Temp\tempxxx.tmp" or one of its dependencies. operation is not supported. exception HRESULT: 0x80131515
Thoughts?
Re: Installing DLL Issue
Posted: Fri Jan 20, 2017 1:35 pm
You need to unlock the dll file after downloads. See the installer How-to here
https://www.plugins4labtech.com/pages/h ... to-labtech
Posted: Fri Jan 20, 2017 7:11 pm
by jerbo128
I have tried that, and just did again. same exact error.
Posted: Fri Jan 20, 2017 8:33 pm
Did you close and reopen the LT console after the lock notice?
Some people will switch LT consoles. I.E if you are on the LT server , try installing the plugin using the a workstation console.
This typically resolves the issues.
Posted: Mon May 13, 2019 7:50 pm
by SamOrlando
jerbo128 wrote: Thu Jan 19, 2017 10:12 pm
Thoughts?
I've gotten this before when installing Automate plugins. I closed the Control Center and then in Task Manager kill all LTClient processes.
I then cleanup the Temp files referenced in the error (I just cleanup the whole folder).
I then relaunch Control Center and reinstall the plugin without issue.
Posted: Tue May 14, 2019 1:25 pm
Correc t, If you get the error and then unlock the file and retry without closing and reopening the LT console it will continue to fail even unlocked.
