Patch Remedy Maintenance Failed
rustrada
Post by rustrada »
We've recently purchased and installed Patch Remedy on LT 11 and this script has been failing with the following error:
The Script(2042) failed in the Then section at step 14. The reason: SQL Execute failed processing query
Script: S2042 - Starting at Server Time: Tuesday, November 22, 2016 10:04:02 AM
I'm not sure if this is related or not but Patch Remedy has been scanning our system hourly but always returns 0 Systems Scanned, and in the Patch Success tab will show many systems with a patch score of 0% or 100% when that is not accurate.
How can I fix the script and have patch remedy show me accurate info?
Thanks!
Re: Patch Remedy Maintenance Failed
Sounds like your issue maybe the "old" missing column in WUA table that causes this error.
To fix do the the following in SQLYog on the LabTech server.
DROP TABLE plugin_sw_patch_remedy_wua
Afterwards restart the LT DBAgent service so it will recreate the table.
Next allow 1 cycle to run for Patch Remedy and recheck scan host value. You should now be getting the data back correctly.
