Build 1.0.3.14 Released (New Features)
Released today is build 1.0.3.14 of Patch Remedy,
We have updated the maintenance script in the version and also added a new exclude feature to allow you to better control what systems are included in Patch remedy scans and data views.
If you want to exclude part of a client, a location or just a computer you now can with the new Client Excluded tool for Patch Remedy.
Found on the Client Console Tab Select 1 or more locations or computers to exclude from the Patch Remedy processes and views
Want to quickly exclude just 1 system without leaving the Patch Remedy console? Right Click the system in the Patch Percentages view to add that system to the excluded systems.
efiniste
Re: Build 1.0.3.14 Released (New Features)
Post by efiniste »
Thanks Shannon, this fixed my 2 problems.
I have 1 PC that's not showing the latest version, it's still showing 1.0.3.10
Version 1.0.3.14 is showing as installed in plugin manager and I get that version if I log in from a different PC.
Is there a cache that needs clearing for CC?
Thanks,
Steve
Yes, this is a common problem with the LT console not updating the plugin DLLs.
To fix goto c:\programdata\labtechplugins\servername
and delete the server named folder you are connecting to. You may have 2 or more folders here one being a netbios name of LT server and one a FQDN of LT server. You can safely remove both and they will rebuild on next connection with latest plugins versions.
efiniste
Post by efiniste »
That's sorted it. Thanks.
Excluding a location seems to not be working correctly.
When I check the box to exclude a location and click "Save" above it, the box changes to unchecked and no changes are made. On the same page, if I check all of the machines at a location and then click "Save" those boxes remain checked and the box for that location also becomes checked.
I'm guessing I should be able to exclude all the machines at a location with 1 check. If so, it's not working.
Steve
really? and you did restart the DBagent, so new tables were created?
No you are right! something must of hiccuped in the code after testing. Give me a quick minute to see whats going on and we will get a fix out.
Well gives me reason to go ahead and put in Windows 7 rollup as the new default for automatic fix for WUA on Windows 7 and 2008
efiniste
Post by efiniste »
Great. Thanks Shannon.
We just posted up build 1.0.3.16 which has the (fat fingered) fix for locations in it and added an update to automated updates to push Windows 7/2008R2 June Rollup KB3161608 during automated WUA updates.
