Table Size
Posted: Mon Jul 18, 2016 2:58 pm
by vkent39
Our h_commands table is over 4.5GB causing our system to constantly run at 100% CPU. Any suggestions to reduce the impact on the server?
Re: Table Size
Posted: Mon Jul 18, 2016 6:54 pm
That is the history table for already executed commands.
You can lower the command history retention
- Capture.PNG (45.54 KiB) Viewed 8053 times
