still lots of weird issues
Posted: Fri Jul 08, 2016 4:32 pm
Is there a good way to completely wipe the system of everything from Chocolatey and start over? I just deleted 50 'pages' of one time scripts scheduled for 7-01-2016, and I still have more to go. Im not sure what my particular issue is, I have already accidentally deployed thunderbird to 800 computers (which the uninstall doesnt work, so you have to manually uninstall it on the desktop). Im just having all kinds of problems with scripts, labtech crashing (could be other plugins who knows right now).
At this point I want to completely remove my entire labtech install of all chocolatey references, and decide if Im going to start over or do something else as I am spending more time cleaning up things then proactively handle things.
One-Time scripts arent deleting
Workstations are randomly locking up with lttray.exe (could be something else, but I have removed almost every other plugin at this point)
Deployment isnt working as easily as I thought. The ease of use is there but then Im not seeing the results I expected, so I end up going back and manually adding an item to a bunch of pc's individually because Im concerned that I will put the wrong software system wide.
uninstall isnt working properly for at least one app (this is a chocolatey thing not the plugin)
