Computer drop-down list randomly sorted
tlphipps
Post by tlphipps »
In setting up the plugin, finding our preferred 'scanner' computer was rather difficult as we couldn't find any logical sort order applied to this list. It would be nice for it to be alphabetical and/or separated by client to help in locating what we're looking for.
We found you can type in the box but couldn't figure out how to make that filter or sort in any way that was helpful.
tlphipps
Re: Computer drop-down list randomly sorted
Post by tlphipps »
So I just figured out how to filter the list. If you click on the drop-down first so it's visible, and THEN start typing. It does filter the list and makes it a little easier to find what you're looking for.
