Registry Cleaner scan button missing
Posted: Wed Mar 23, 2016 3:10 pm
by iternalnetworks
Our installation of Cleaner is missing the button to scan on the registry cleaner tab.
- registry.PNG (17.6 KiB) Viewed 12966 times
Is there a step that I am missing to enable that? I am running the 30 day trial of the plugin and I have made sure that the agent I am testing shows that is has a license it is using.
- Mike
Re: Registry Cleaner scan button missing
Posted: Thu Mar 24, 2016 1:18 pm
Mike I believe that was disabled in demo mode. Let me check. Can you post license counters and date here so I can confirm what the plugin sees as license info.
- 19.png (4.68 KiB) Viewed 12961 times
Posted: Thu Mar 24, 2016 4:24 pm
by iternalnetworks
Here it is - also, the computer that I have been testing is the 1 that shows with the license issued.
- registry.PNG (3.46 KiB) Viewed 12960 times
Posted: Thu Mar 24, 2016 4:36 pm
That's why! When systems do not show as installed they hide any buttons that would force app to run.
Click the gear symbol to open manager to see what's caused deployment failures. 33 systems are not deploying which may be due to demo mode only allowing 1 install.
