Page 4 of 5
Re: Error running Stalled Agents
Posted: Mon Apr 04, 2022 12:40 pm
The POSH errors are the 3 commands run to restart the service,
#1 LTService stop
#2 LTSVC.exe killtask
#3 LTService Start
All 3 failed which means another issue is a foot.
So What I have done is updated the error output for this window to
#1 include the task its doing in log, add the command being run in POSH to the error window.
You can copy and paste the command in to POSH and execute to see why its failing and the return received.
You also mentioned that the URL was malformed? Can you elaborate on that and how you " fixed it"?
Posted: Mon Apr 04, 2022 12:58 pm
by jtzabecki
url has a / at the end, removed that and it seems to have fixed the issues. Also on the domain for origin. found that sub dowmains are not supported.
Posted: Mon Apr 04, 2022 12:59 pm
by jtzabecki
what is the newest version of this plugin.
Posted: Tue Apr 05, 2022 1:29 pm
Posted: Tue Apr 05, 2022 1:48 pm
by jtzabecki
Then how do I have what the zip file called was 1.0.17
Posted: Tue Apr 05, 2022 2:45 pm
Doh, Thanks for pointing that out. I still had the meta field set to 1.0.16. Would not effected your download email but did set the DL link you would see in account manage to wrong version.
https://delivery.shopifyapps.com/-/7144 ... bec3879f8d
Posted: Tue Apr 05, 2022 3:18 pm
by jtzabecki
Oh ok so I have the newest version
Posted: Tue Apr 05, 2022 7:14 pm
Can you elaborate on this? Just so I understand what happened here?
jtzabecki wrote: Mon Apr 04, 2022 12:58 pm
Posted: Tue Apr 05, 2022 7:40 pm
by jtzabecki
url it was pulling for control from automate was
https://myhostedomain/ So when it went to try and run the screen connect it could not because it was putting the logic as
https://myhostedomain/:portnumber. By removing the / on the domain for my control in the automate integration it now shows it as https://myhostedomain:portnumber when it connects. Which makes it work.
Posted: Tue Apr 05, 2022 8:34 pm
can you post a screen shot on where you changed that value? I want to make sure we can covey that info to others whom may have a similar setup.
