Help in debugging Failure to Download ISO in Google Drive
jallenEITP
Re: Help in debugging Failure to Download ISO in Google Drive
Post by jallenEITP »
I worked around our issue by deleting the profile and re-adding a new one using the same exact files. Now it works. There maybe something with the profile that is wrong as it was working before then stopped.
first we need you to post the output script log here so we can see what your seeing. The original post is using someone elses data and not yours.
What was the log output in the plugin for agent? can you post a screen shot of that as well. Next Post a image of your setup so we can see what you have where in the configuration.
