Good Afternoon!
I've been struggling to get Powershell versions upgraded using the PoSH plugin. Most of the servers that I have tried pushing the update through the plugin have not updated.
Two entries are generated under Scripts on the endpoint:
Information: Powershell update to 4 has been started.
Result: The Script(6169) was successful in the Else section.
Script: S6169 - Starting at Server Time: Monday, September 17, 2018 12:15:47 AM
The endpoint that I am testing against is running the follow:
Windows OS - Server 2012 Standard
.Net:
DELETE FROM  `plugin_sw_powershell_dotnet_versions` WHERE ComputerID = '3714' ; INSERT IGNORE INTO `plugin_sw_powershell_dotnet_versions` (ClientID,ComputerID,NetName,NetVersion,NetRelease) Values ('2', '3714', 'Client (4.6.1)', '4.6.01055', '394271')
,('2', '3714', 'Full (4.6.1)', '4.6.01055', '394271')
,('2', '3714', 'Client', '4.0.0.0', '')
Powershell:
REPLACE INTO `plugin_sw_powershell_versions` (ClientID,LocationID,ComputerID,Major,Minor,Build,Revision,LastScan) Values (2,316,3714,'3','0','-1','-1',NOW())
Our environment has a lot of Powershell version 2 and 3 installed in it that we need to get to version 4 at a minimum. Getting this to work will save me a tremendous amount of time.
Thank you
- Robert
						Updating Powershell with PoSH
Re: Updating Powershell with PoSH
Robert,  Can you send us the results of the commands tab during the script run.  We need to see the return.
Is this what your looking for? I ran the upgrade to Powershell 4 against a machine that the plugin is showing as Powershell 3. After the script completed the server did not reboot and Powershell still reports at being on version 3.
Execute Command - Success - 12/11/2018 9:21:01 AM
Parameter:
cmd.exe!!! /c "@powershell -NoProfile -ExecutionPolicy unrestricted -Command $PSVersionTable.PSVersion.Major"
Output: 3
Scripting KeepAlive - Success - 12/11/2018 9:21:17 AM
Parameter:
15
Output:
OK
Invoke Script - Success - 9/21/2018 9:21:19 AM
Parameter:
1|t+3W7tDAxeTWTQn5C/bVxZDKGwLrfLBoJfIQY1BoKWy4PxqGj9BC1w7zG4XQJkCtOeLHdL4XUB8iOAo9a897LWByVE2tOPQ8AIu59mBmbaII1gYQjg9F1cxqKeenGXRuLzKzztmlp4bKzDa1OOA2D8ubghOu2ly5Q3QkkW+H6dcR84QOn67vwRv0yAecpfhXGJpRcN0JuDD/XwNvyJw6pFCsbL8iYxTYWTayVt9m7LRj0O8iCAxGQ5Mhlk0/g8bE9d/lFCZ0gMkIo6wc7tsSeI8QetNvAs7AW3dQe9hj7RSirWRM0q5W2xorVmY4r0XKG7HwI6dYg10TYnFuYjkban+1VeLmrm/r|t+3W7tDAxeS+6CYhhD1YbVhOHsuyZygw|t+3W7tDAxeS+6CYhhD1YbVhOHsuyZygw|t+3W7tDAxeS+6CYhhD1YbVhOHsuyZygw
Output:
4.6.01055|4.6.01055|4.0.0.0|
DownLoad URL - Success - 12/11/2018 9:21:31 AM
Parameter:
https://download.microsoft.com/download ... 819745.msu
Output:
OK Downloaded File https://download.microsoft.com/download ... ltiPkg.msu and saved as %windir%\ltsvc\Windows6.1-KB2819745.msu
Execute Command - Success - 12/11/2018 9:21:36 AM
Parameter:
cmd.exe!!! /c "wusa %windir%\ltsvc\Windows6.1-KB2819745.msu /quiet /forcereboot"
Output:
OK
Scripting KeepAlive - Success - 12/11/2018 9:21:47 AM
Parameter:
15
Output:
OKIs this what your looking for? I ran the upgrade to Powershell 4 against a machine that the plugin is showing as Powershell 3. After the script completed the server did not reboot and Powershell still reports at being on version 3.
Parameter:
Output: 3
Parameter:
15
Output:
OK
Parameter:
Output:
Parameter:
Output:
Parameter:
Output:
OK
Parameter:
15
Output:
OK
Parameter:
Output: 3
Parameter:
15
Output:
OK
Parameter:
Output:
Parameter:
Output:
Parameter:
Output:
OK
Parameter:
15
Output:
Parameter:
Output: 3
Parameter:
15
Output:
OK
Parameter:
Output:
Parameter:
Output:
Parameter:
Output:
OK
Parameter:
15
Output:
OK
Ok A couple of more questions.
What is the OS we are working with? Win 7 Win 10 Etc...
Next if you execute manually on the same agent as before that reports version 3. Log in to the desktop and open a admin command line console on desktop. Copy the following into the command window and run it.
What does DOS report back?
wusa %windir%\ltsvc\Windows6.1-KB2819745.msu /quiet /forcerebootRe: Updating Powershell with PoSH
OS Versions are Windows Server 2008, 2008 R2, and 2012.
When I ran the command from that server using an elevated command prompt there was no message and nothing happened.
Really,  ok lets run just this part..
Does anything get reported? Looking for a Microsoft error like version mismatch or update does not apply warnings.
Got an error that time.
Windows Update Standalone Installer
Installer encountered an error: 0x80096002
The certificate for the signer of the message is invalid or not found.
Interesting..
Let me see if they have a new installer posted.
Interesting..
Let me see if they (Microsoft) has a new installer posted.
Good Afternoon,
I was wondering if you had an update on this?
Thank you!
Thank you!
