Inclusion and Exclusions
revsmitty
Post by revsmitty »
Is there a way to make inclusion/exclusions at the client level in which they will flow down to all the machines. I've changed the software at this level appears I need to go into each location and change the software for Chocolately at the machine level.
Re: Inclusion and Exclusions
This is how it works,
By default once you start up a client any new software added to the Approved list is automatically excluded to all clients and all systems. The reason is to allow you to adjust the app list with out sending all new apps to everyone 5 minutes after you add it.
So you will need to "Toggle" on and off and on or off, on, off for the new Apps at the client level to filter down to the computers.
revsmitty
Post by revsmitty »
Excellent. That makes sense. Will go and try and test it.
