Excludes on or off ?
Posted: Thu Feb 04, 2016 4:44 pm
Among these two entries, which one is indicated as ON and which one is indicated as OFF?
Keep in mind you are “Excluding and Application from install” so is the Exclusion “on” or “off”
If On then you are excluding it if off then you are allowing it.
