Releasing Build 1.0.1.63
Our Squid Squad has the plugin and is giving it a final review before we post it.
-----Build 1.0.1.63 Updates-----
Fixed Encode/Decode Path issues found with international systems and platforms.
Added Decode test tool to test and repair updated LT servers using previous versions of Cleaner For LabTech
Corrected several bugs in deployments, automation and data displays.
Check back here for download information later this week.
europait
Re: Releasing Build 1.0.1.63
Post by europait »
Will this release support LT 10.5? I just downloaded the trial and it appears that 10.5 is not supported as of yet.
europait wrote:Will this release support LT 10.5? I just downloaded the trial and it appears that 10.5 is not supported as of yet.
Works great on 10.5 What is your issues? Are you getting a Unknown error pop up? If so right click DLL file and select "Unblock" before trying to install.
europait
Post by europait »
OK, I did not see 10.5 as supported in one of the pages so I assumed that was the issue. I did unblock the file but get the same error.
"There was an error uploading the new plugin"
Ok try surfing the following link
http://cleaner.squidworks.net/api/versi ... ch&install
It should return the following...
Copy all text and paste it into MySQL WorkBench or MySQLYog and execute it.
Afterwards restart the LT Console to reload plugins.
europait
Post by europait »
It looks like that did it. Cleaner for LabTech is showing in the plugins manager with DB Loaded and IIS Loaded, Remote Agent shows grayed out. I will get into it soon and let you know how it goes!
