Firewall Management
Defender for Automate Software Documentation project.
Firewall Management
The firewall management tool allows you to manage the firewall settings and rules for any Windows agent using Defender.
You can:
  • Enable or disable one or more firewall zones (Domain, Public and Private)
  • Enable or disable any firewall rules
  • Add and remove firewall rules
Return to “Defender Documentation”
