New Build 3.7.0.20 Released
New release available Build 3.7.0.20
Whats been added or fixed over the last few updates.
Get It Here
---3.7.0.18---
Added new Group, Search ,Group script to seek out agents that's Dotnet (4.8) is not compliant with current Chocolatey versions and will attempt to update DotNet to 4.8
Added messagebox pop up after using any of the EDF cloning controls.
---3.7.0.19---
Added new status to the UP column of the agent list, New status is online but pending reboot.
Added new menu option to reboot agent
Added new menu option to Scan Agent
Added tool tips to status column
---3.7.0.20---
Fixed command “choco search” in P4A Scan Packages which may return an warning in its output, before the package and version info.
Fixed issue where selecting to clone a EDF to a client or location did not take in account if Servers or Workstations were disabled.
Fixed typo in log entry causing variable to not be displayed in log.
