Group Members Tab
Posted: Thu May 15, 2025 3:25 pm
The group members tab allows you to select a group and assign, reorder, or remove members from that group.
Group members are computers assigned to the group.
You can Drag and drop computers from the available computers box to the group members box to add computer to group. Drag the items around in the group members box to change reboot order or drag them back to available computers box to remove computer from the group.
You can also access the Group Dependencies form for the group selected using the right click menu.
