Group Management Tab
This forum provides the documentation and descriptions of how the Reboot Manager works. Do not post issues in this forum.
Locked
The group management tab allows you to create, edit and delete reboot groups.
A reboot group is a group of computers that rely on each other, and when a reboot on any one member is needed, the group as a whole will need to reboot in a particular order.
Group objects are:
  • Group Name
  • Delay in seconds between members
  • Description of group
You can access the Group Dependencies form from the Groups list by selecting a group and right clicking that group to produce the menu popup. A group can have soft are hard dependent members. Soft members will not cause the group as a whole to reboot where hard dependent computers force the group to reboot in the order, and the delay setting the group is assigned.
Locked
Return to “Reboot Manager Documentation”
