Plugin failing to retrieve any data
Support and discussion forums for the Plugins4Automate Office365 for ConnectWise plugin.
revero2749
1
Post by revero2749 »
We recently bought the plugin(like in the past week)
I configure it this morning by following the documentation by adding a password on Client location,configuring a new app registration and setting the O365 API permissions(3 of them)
I have configure a single Client by adding the tenandid,client value and secret value(no not the id :-D)
Get MSOL status seems to pass partially as I the probe date changes and a few of the grey "lights" turn red or green
But when scanning a Client,none of the data is able to be retrieved
Checking the commands I think it appears that the Connect-Msolservice part in one of the scripts is the root cause
Output:
Connect-Msolservice : One or more errors occurred. At C:\Windows\temp\Office365\OOFStatus.ps1:249 char:2 + Connect-Msolservice -cred $cred + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : OperationStopped: (:) [Connect-MsolService], AggregateException + FullyQualifiedErrorId : System.AggregateException,Microsoft.Online.Administration.Automation.ConnectMsolService Method not found: 'Microsoft.Identity.Client.PublicClientApplicationBuilder Microsoft.Identity.Client.Broker.BrokerExtension.WithBroker(Microsoft.Identity.Client.PublicClientApplicationBuilder, Microsoft.Identity.Client.BrokerOptions)'. At C:\Program Files\WindowsPowerShell\Modules\ExchangeOnlineManagement\3.7.2\netFramework\ExchangeOnlineManagement.psm1:754 char:21 + throw $_.Exception.InnerException; + ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : OperationStopped: (:) [], MissingMethodException + FullyQualifiedErrorId : Method not found: 'Microsoft.Identity.Client.PublicClientApplicationBuilder Microsoft.Id entity.Client.Broker.BrokerExtension.WithBroker(Microsoft.Identity.Client.PublicClientApplicationBuilder, Microsof t.Identity.Client.BrokerOptions)'. WARNING: The version '1.4.8.1' of module 'PackageManagement' is currently in use. Retry the operation after closing the applications.
Now I know this plugin has been updated quite a while back and Microsoft has been moving lots of stuff around to use graph instead.
Could the registered app API permission be the issue?
Theres also this from the exec_MSOLStatus.ps1 script:
#Endpoint URI to get Service Communication Messages
$Uri = "https://manage.office.com/api/v1.0/$Ten ... s/Messages"
#Get the last run time of this script from the registry and query for incidents happened or updates posted after that time only
$CurrentDateTime = (Get-Date).ToUniversalTime()
$CurrentDateTime = $CurrentDateTime.ToString("MM/dd/yyyy HH:mm:ss")
$LastRunTimeOfThisScript = GetLastRunTimeFromReg $CurrentDateTime
$Culture = Get-Culture
#Call the API to Update the property, look for incidents only ($_.MessageType -eq "Incident" -and)-and (($_.LastUpdatedTime).ToDateTime($Culture)).ToUniversalTime() -gt $LastRunTimeOfThisScript
$Responses = (Invoke-RestMethod -Uri $uri -Headers $Headers -Method Get).Value | Where { $_.Workload -in ($Workloads) }
The $uri immediately returns a 404 - File or directory not found
I really would like this to work as this is quite an exciting thing to play with
Re: Plugin failing to retrieve any data
Honestly, I can believe that. Microsoft is always changing how things are done. If you don't keep a dedicated team on it, they will change something that hoses up the whole thing.
Looks like it hasn't been modified in quite awhile. Your the first person to put in a notice of issues for this.
I would be happy to have a look at this and see if we need to make some modifications to comms for what MS has changed.
Would you be willing to work with us offline to facilitate the updates?
Return to “Office365 For Automate”
