report for chocolatey updates
frankbe
Post by frankbe »
Is there a report like third party patch audit for this plugin ?
Re: report for chocolatey updates
zNot yet but we are working one one. This is being covered in another tread.
This tread is for Automate Package Manager but both APM and C4A are in the same family, and what is developed for one, is also developed for the other.
viewtopic.php?t=6532
frankbe
Post by frankbe »
do you log in a table, what the plugin is doing ?
BTW: search for "reports" or "report manager"
the following words in your search query were ignored because they are too common words: reports
you must specify at least one word to search for. Each word must consist of at least 3 characters and must not contain more than 14 characters excluding wildcards.
the search function in this forum software is really annoying
Data base tables.
Screenshot 2025-03-24 095903.png (6.16 KiB) Viewed 2875 times
