disable P4L PoSh Maintenance script?
AlexU
Post by AlexU »
I'm wondering if there is a way to disable the P4L PoSh Maintenance script?
I'm not sure what it's doing, but it seems scheduled against every single endpoint we have.
In the configuration for the plugin, there is nothing enabled to automatically upgrade, so I feel like it's just spaming the logs full :)
Kind regards,
Alex
Re: disable P4L PoSh Maintenance script?
The scrip is scheduled daily to run on each online agent to query the current dot net and PowerShell versions on agent. It will not update any software unless you have set it to.
The script logs should be being purged out daily for this script name so you do not get logs cumulating over time. We do not provide an ability to turn it off.
