Is it possible to change / skip update types?
LHChris
1
Post by LHChris »
The vast majority of our clients have a bad score in PR because they are missing driver updates. We do not install driver updates unless we are trying to solve a problem.
Is it possible to have PR ignore types of updates like driver updates?
Re: Is it possible to change / skip update types?
We do not provide a way to ignore certain updates in Patch Remedy. Patch Remedy was designed to be a stark reminder of where your agents are at in the realms of updates and security fixes.
Even drivers can have exploits, neglecting drive updates could allow for kinks in ones armor just as any other update potentially.
Return to “Patch Remedy 5”
