Issues with MassDeployment and Update Now
ryan.gallienne
1
Post by ryan.gallienne »
Hi
We are having issues with the Mass Deployment and Update Agent commands. I did some investigation and found that the command being sent appears to be wrong.
It is using the -File when referencing an .exe which gives this error
PS C:\windows\system32> Set-ExecutionPolicy Bypass -Scope Process -Force; Start-Process -FilePath 'powershell.exe' -ArgumentList '-file C:\programdata\chocolatey\bin\choco.exe upgrade all -y' -NoNewWindow
PS C:\windows\system32> Processing -File 'C:\programdata\chocolatey\bin\choco.exe' failed because the file does not have a '.ps1' extension. Specify a valid Windows PowerShell script file name, and then try again.
Windows PowerShell the latest version available based on your source(s).
Copyright (C) Microsoft Corporation. All rights reserved.ased on your source(s).
running the below in PS locally works, can this be changed?
PS C:\windows\system32> Set-ExecutionPolicy Bypass -Scope Process -Force; Start-Process -FilePath 'powershell.exe' -ArgumentList 'C:\programdata\chocolatey\bin\choco.exe upgrade all -y' -NoNewWindow
Ryan
Re: Issues with MassDeployment and Update Now
Hmmm, I wonder why we wrote it that way? That was a bring over from 3.0 and 3.5 where I guess PowerShell was a little less stringent.
Anyhow, We had like 6 occurrences where we made calls in that manor. I have gone and corrected them all.
3.6.0.11 has been released and should auto update tonight. If you want it faster, you can download and update plugin by logging into your account on plugins4automate.com and downloading the latest build from your subscription admin.
ryan.gallienne
1
I have updated and this is working now, thanks for the quick response.
