Policy Editing
dplx
Policy Editing
Post by dplx »
how am I able to edit one of the created policies? I just found an option for deletion of policies.
Regards Dennis
Re: Policy Editing
The current process is
Create a Policy, if you need to edit policy afterwards, delete and recreate. I will work on adding in the ability to reload a policy into the policy form for editing.
bmartindcs
Re: Policy Editing
Post by bmartindcs »
Cubert wrote: Tue Feb 13, 2024 3:35 pm The current process is
Just purchased and got setup, only to have trouble trying to edit a policy. So I came here to see what I was doing wrong, then saw that you can't even edit the policies.
This would be really helpful if you could make the editing work as that feels like it will be one of the main things we would do over time in the tool as client needs change etc. Delete and recreate then requires reassigning it everywhere, and possible (have not tested) reinstall work that wouldn't be needed otherwise.
Re: Policy Editing
Agreed!
I will bump that up the list of to-dos.
