Install Individual Packages Missing
Posted: Fri Dec 08, 2023 12:21 pm
by matthewa
Hello
Back in February on 1.0.25 we were able to open the agent and install individual plugins, i took screenshots for a Wiki on how back then.
However, this feature seems to be missing on 1.0.26 and i am not sure why. We have removed LUM Plugin and the two database entries and reinstalled the LUM plugin but makes no difference, the right click and select option is no longer there.
Has this handy feature been removed or do we have another problem?
Matt
Re: Install Individual Packages Missing
Posted: Mon Dec 11, 2023 1:26 pm
I don't believe it was removed.... Let me go have a peek and see.
Posted: Mon Dec 11, 2023 1:33 pm
I am not seeing that function in the plugin currently, depending on how the function operated maybe there was a issue with it? I can not answer as I just don't remember that far back. :roll:
What I can do, is in the global view of agent, add a menu item to allow you to pass a package name to the end agent for direct install.
GIve me until noon or so, should have that punched out quick enough.
Posted: Mon Dec 11, 2023 3:03 pm
Here is build 1.0.27.
https://delivery.shopifyapps.com/-/ac68 ... a0b13b056b
Menu
Installer
Posted: Thu Dec 14, 2023 10:18 am
by matthewa
That's brilliant! Works for us.
Many thanks Cubert :D
Posted: Thu Dec 14, 2023 1:49 pm
Glad to help!
